Old 09-16-2003, 05:41 PM
PCC's Avatar
PCC PCC is offline
Thanks for your prompt reply Mike - You must be like me and work from home.
Banana Benders hey - a new one on me.
Pineapple heads maybe!
As i'm a pomme living in Queensland I feel a bit like a bitzer (bits of this, bits of that) - Anyway the sun keeps shining.
Back to the technical issue:
Yes the cobra is fuel injected with a 70l tank and in tank high pressure fuel pump.
The tank was between half and 3/4 full as there aren't many fuel stops in the "mountains". However the roads were pretty steep in areas so may be the fuel was sloshing to the back of the tank (or maybe not).
I am aware of the fuel return noise although this is more of a hiss (maybe thats why the cars are called cobras!)
The noise I experienced was quite a high pitched constant whine increasing in severity as I climbed higher - Never done it since.
Regards the Nationals, when are they held in South Brisbane as Sydney / Canberra is a little far to travel (although I do fly into Sydney on a regular basis).
Finally,
Craig, Scott and Les - Where do you hide out as we would like to catch up with you some time.
PCC
