Old 09-17-2003, 02:26 PM
Gordon Levy's Avatar
Gordon Levy Gordon Levy is offline
Cobra Make, Engine: Car builder/restorer FFR
No not at this time. It's pretty simple stuff though. I have had good luck hanging them right off the side of the carb on the fuel inlet side. Usually a little up and away from manifold heat. Use a homemade bracket and the carb mounting studs or machine right into the side of the log and run hard line up to the Holley. You will need cathedral bowls for this but if you do it that way you can run the feed line right into the end and let the log hang from the hard line.
Pro builder- www.levyracing.com
www.facebook.com/levyracing
