Old 09-18-2003, 05:55 PM
REDSC400's Avatar
REDSC400 REDSC400 is offline
Cobra Make, Engine: ERA #375 427 S/C - 428FE - Toploader - 1968 AMX 390 Go Pack 4 Speed - My Daily Driver is a 2004 Crossfire
Send a message via AIM to REDSC400
Default Yup... the Pickup inside the Distrib is My Guess...
Well, I recently had the same problem. Check the MSD and that was not it. Checked the coil it was putting out via the MSD test. The sensor unit inside the distributor, (Mine is a Mallory Unilite) was bad. Darned expensive little item. I think I will always have a spare around to boot.
This things are the most delicate in the chain of the charge. Any power spike or sever variance will indeed play havoc with them. SOmetimes a jump starting or battery charger will whack them as well. I think you can somewhat protect the unit with a power ballast resistor or one step above that is a power conditioner. How effective those are I do not know.
I think a spare coil, rotor, and distributor sensor switch, fanbelt and one or more spark plugs are pretty much (Must haves) in the way of spares.
Hope you find the problem.
Art in CT
See My Website at http://www.lithicsnet.com
A car can massage organs which no masseur can reach. It is the one remedy for the disorders of the great sympathetic nervous system. Jean Cocteau 1889-1963, French Author, Filmmaker
