Old 09-18-2003, 06:19 PM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Think the MSD low resistance 8.5mm wires are the best on the market. Was using Ford Motorsport 9mm wires until I compared the actual wire size between the FMS, and MSD. MSD wire inside the insulation is 3x the the size of the FMS.
MSD does some pretty boneheaded stuff; like not putting an adjustable vacuum advance unit in their vacuum advance distributors, and not telling you how to install one.
But their plug wire sets are first rate. If you spring for a set, get a container of their boot lube and use liberally on inside of boot. Boots tend to stick to plugs when changing them and you have to replace the boot.
