Old 09-20-2003, 11:06 AM
Sizzler Sizzler is offline
Originally posted by Anthony
Regarding the rods, you would probably regrind the journals for BBC rods, and use something like a 7.0" length, for a high rod/stroke ratio.
pistons would be custom.
As for the heads, probably something like Dove tunnel port with the raised exhaust ports.
It definitely would be something different.
I've thought about this too. Questions to myself were, given the heavier crank, AND the longer (heavier rods), what if anything would be gained as far as wind-up speed? Add to such a motor the high # springs in the valve train needed to control things at the projected max rpm, and yes, at 7-8K rpm, the engine would scream, but anywhere below that rpm range you'd probably be down on power and hurting yourself. My opinion then and now is it might make sense on a race engine/car, but not much sense with regards to a primarily street driven car.
Such an engine though might be better matched to the trans/diff ratio's that seem to be available. Lower torque would make 1st gear something to use again, and a 5th or 6th gear could potentially be run all the way through. 198+ anyone?
