Old 09-20-2003, 12:20 PM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
The Hella U.S. DOT approved are knicknamed "Vision Minus". Best is Cibie European spec lights. Use the 55/100, or 85/100 H4 bulbs. Look around the net and you can find them.
That being said, these lights need a lot of juice and need relays, 1 for the lows, and 1 for the highs. Wire dimmer switch to relay, pull lights power direct from battery. Headlight power wire needs to be at least 14 ga, and preferably 12 ga.
