Old 09-21-2003, 11:25 AM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
All ignition switches operate about the same. I have a Lucas switch, but used a Ford F150 pickup key switch instead.
First, you don't ground the switch, it's a power feed only.
On the back of the switch should be a battery power in, accessories, ignition, and start. Turn the key to the left for accesswories only, key to the right is ignition. Both accessories and ignition should be hot. Twist the key to the right is start. Ignition will be hot, start will be hot, and accessories will be off.
Using a multimeter, figure out which is which.
Accessories is anything you want turned on and off by the ignition switch, but off in start. Your radio, for instance.
Ignition is just that. Goes to your ignition power. Start is just that. Goes to your starter solenoid. Keep all your desired safety devices, trans in neutral, connected in series.
This help?
