Old 09-22-2003, 06:02 AM
Aussie Mike's Avatar
Aussie Mike Aussie Mike is offline
It's a fabricated pedal box. Ian gave me the laser cut blanks for the pedals and the brake pedal is cut to take a weld in Tilton balance bar. I've machined the pivot bushes and I'm piecing it all together at the moment. I'll weld them up when I'm happy with it. I'm probably going to fit a bias adjustment knob on the dash after it's registered.
I've got some AC script alloy treads that I'm attaching to the pedals so it should look good when it's all done.
On Ian's advice I went for 3/4" front 5/8" rear for the brakes. Ian reccomended 1" for the clutch but I could only get 7/8". I might just have to change the pivot or shim out the throw out bearing.
These Wilwood remote cylinder kits are great. I hope they perform as good as they look. The kit comes with 2 different sized reservoirs that can be connected via the hose supplied or plugged directly on the cylinder. It makes it pretty flexible for fitting them to different applications. They look to be pretty good quality and a reasonable price too at AU$148 each.
Mike Murphy
Melbourne Australia
