Old 09-22-2003, 11:24 AM
MIKE SCHULZ's Avatar
MIKE SCHULZ MIKE SCHULZ is offline
Cobra Make, Engine: Contemporary 427 CCX 3627 ,TKO 600 RR,TWM 58mm DFI
Wink Info Needed...on F.E Block
Gentlemen; I was just dissassembling a Solid lifter F.E Motor over the weekend and the Block numbers are: Front - 352 , Rear-352 ,Lifter Valley- 47 and no other numbers identifiable. Pistons said 390 on the sides.My question is: Under the middle of the three frost plugs on either side of the block there is a "thin" wire ( Mabey .075" thick or so ) that runs from the cylinder head deck ( On the inside water passage area) to the Cylinder base ( Inside the water jacket).What`s this for?? ,Is it a factory aligning device that helped the factory when casting the block??. And what if a person happenned to break it off with a screw-driver .I appreciate your reply....Mike.....Oh Yea!, I`m looking for a Glenwood F.E Timing Cover for my Marine motor..Thanks
