Old 09-22-2003, 08:03 PM
mstngjoe's Avatar
mstngjoe mstngjoe is offline
I will assume you are talking about a SBF engine. If so, those 65cc heads just will not work if you want 10.0:1 cr.
Here's an example:
Bore............4.030
Stroke.........3.00
Cylinders.....8
Head CC......65.0
Piston vol.....-6.0cc (valve reliefs)
Gasket thickness + deck height--------.034
This is assuming you run the piston .005 OUT OF THE BORE & a .039 compressed head gasket.
With this setup you would have 9.02:1 static compression ratio.
My advice would be to find some 58cc heads and run a zero deck height with the .039 gasket. That gives you an excellent quench of .039. You should be able to run 10.5:1 with aluminum heads no problem.
Here is a link to some engine calculators:
http://www.kb-silvolite.com/temp/calc.php?action=disp
Good luck and have fun.
'89 LX 408...SCAT, Probe, AFR 205, Vic Jr, Pro-Systems, Rawls sft cam, UPR K & arms w/coil overs.....more to come!
