Old 09-23-2003, 04:02 PM
ed cougar ed cougar is offline
Default Pulsating idle help
Hello, and thanks to all who respond, my 428 SCJ has this pusating idle, the air adustments on the 735cfm are responsive when I turn them in the idle roughens then back a little an it smooths right out but still has that pulsating, the timing mark also hunts a little with the pulse, what would be the most probable cause- valve adjustment-worn distributer shaft? Could the manifold be leaking vac. and whats the best way to check, it pulls about 14Hg at idle and it also hunts a little with the pulsing idle. The cam is a crower nothing ratical 530in 531ex 110* overlap. I can enter more specs but I think I'm missing something simple and hopeing for a good tip. Thanks alot.
