Thread: alignment
Old 09-24-2003, 04:35 AM
Default With or without weight in Driver seat?
These alignment numbers, are with or without weight in the drivers seat. The alignment will change with a 200 lb man in that side of the car. camber and caster will be different. BMW or Mercede's has you put weight in the car before you set the alignment. The caster should be .3 less on the L/S of the car if you don't put weight in the car and camber should be .2-.3 different for your weight on the L/S. Rick Lake ps everybodys car is different, this is what my car likes. I have a power rack in my car and the caster is 3.5. without the rack it would be in the 2.0's. my 2 cents. Rick Lake
