Old 09-24-2003, 01:22 PM
decooney's Avatar
decooney decooney is offline
Updated application procedure:
* Use Alchohol to clean your glass vs. Windex. Less residue.
* Use a pindrop of dishsoap in a spray bottle, apply water film to glass to help push out any air bubbles you might create
* Soak the glass right as you are laying down sticker (get a helper to spray for you as you lay it down)
* If you have a film of water under sticker, you can use the water to push any bubbles out. No Water usually = bubbles unless you are a pro at this doing them dry!
* Apply sticker from left to right or right to left. Not from middle.
* As you lay it down, swipe right behind it with a credit card to prevent bubbles and to keep it laying down evenly
* You can soak the fuzzy protective layer before you remove it
* If it does not work out, we can always send three more.
I've tried this a few times now, and using water helps to push the bubbles out more than attempting it dry. Have Fun!
If someone comes up with any better ways, please let us know. So far this seems to work okay.
Duane
