Old 09-25-2003, 12:26 AM
Aussie Mike's Avatar
Aussie Mike Aussie Mike is offline
Re insulation, I've seen some thin foam sheeting backed with foil on both sides. It should be pretty easy to cut, shape and glue into the foot wells and on the tunnel.
I remember seeing the Barina reservoir caps when I visited Ian a while back. I was planning on using them but I also thought there had to be a pressure switch in line that detected when either the front or rear brake circuit failed.
Aluminium radiator and header tank are next on the candygram delivery schedule.
I think Stuart and many others are still waiting on Rego. The RTA fella has got a bee in his bonnett about not having a brake booster fitted. The precedent has been set by other cars already so I don't see how they can knock it back. I think they are waiting for a decision to filter down from higher up.
Mike Murphy
Melbourne Australia
