Old 09-27-2003, 10:20 PM
CJ428CJ's Avatar
CJ428CJ CJ428CJ is offline
Cobra Make, Engine: ERA #629, BBM Side Oiler Block, 482ci, Richmond 5 speed
Check out this link. http://www.cranecams.com/mliftfaq.htm
How you adjust them hot vs cold varies based on aluminum or iron head as well as aluminum vs iron block. The rocker arms you run make a difference too. I have a steel block, aluminum heads and the Erson rocker arms and I've found that .008 gives me a perfect .018 hot.
