Old 09-29-2003, 12:05 PM
Cammer's Avatar
Cammer Cammer is offline
Cobra Make, Engine: ERA 427 SC - #463 - 427 SOHC
Default Fuel Pump Running???
Bob,
FYI - I spent several hours trying to trace down the cause of my fuel pump running continuously - it ran in the ignition on, ignition off and the accessory position - As it turned out the turn signal flasher was apparently stuck with the lever in the off position - continuing to feed power to the pump through the flasher circuit.
Jiggling the switch corrected the the problem and now all is okay for the moment.
Thought you might like to know!!!
Dee Walters/CAmmer
