Old 09-30-2003, 09:59 AM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
The oval air cleaner is probably the most restrictive air cleaner you can put on that or any motor. Take a look at the K&N 11" with the top filter. It's ugly, but it flow air.
For show, Edelbrock makes an oval air cleaner that should fit, or at least clear the distributor anyway. The element is also a K&N and will fit the 11" K&N unit above, but with a slightly taller element.
