Old 09-30-2003, 10:23 AM
TonyMadrid's Avatar
TonyMadrid TonyMadrid is offline
Cobra Make, Engine: A&C 351W, C4
Default power to column
Two items: First, there should be some power wires from the column harness that would run to the fuse panel. Such as horn, turn signals, hazard lights. Has it already been wired or are you still in the process?
Second thing, if it is already wired in place and you still have no power, make sure that the column harness is grounded and you may even have to be sure that the column itself is grounded.
Good Luck,
Tony
