Thread: Temec or T5
Old 09-30-2003, 05:43 PM
aumoore's Avatar
aumoore aumoore is offline
Cobra Make, Engine: Hunter 427, 5.0 (302)
"Liberty explained, the T5's weak link is the shifter forks. When these things bend during power shifting, the trans blows. Solution is use a positive stop shifter. Mine is a Hurst."
I had a Hurst and a T5Z and I still broke third gear on a road course without powershifting. The T5 is fine if you never, never, never plan to run it hard. It may last longer in a Cobra due to less weight but it will break.
I say at least upgrade to a3550 in you have a mild to wild Normally asperated small block(under 360c.i.) If you run a power adder, stroker or a big block get the TKO.
If you are thinking T-56 forget it. It is not any stronger than a 3550 and it has more gears to break. Ask Jim Pomroy about a T56 behind a supercharged 351. He broke it.
Click here for DSCC website
