Old 10-01-2003, 07:46 AM
DAVID GAGNARD's Avatar
Tony;
I've seen a number of Edelbrock fuel pumps leak,not sure why,but have seen problems with them.... I have a Carter on my car,been there for almost 20,000 miles and have had NO problems with it,it's also a lot less expensive then an Edelbrock....
As far as the carb goes,I'm with Mr. Fixit on this one....Tried that a few years ago on a Holley 600 on a pickup truck,did not cure the problem,the only thing that cured my problem was replacing the carb....I would put a power valve with a very low opening (2.5 or so) and work on jets,if that does not work,try another carb.....
David
DAVID GAGNARD
