Old 10-01-2003, 08:18 AM
Hotfingrs's Avatar
Hotfingrs Hotfingrs is offline
Cobra Make, Engine: EM cobra, 450 inch sbc running a best ET of 9.14..so far..ALL MOTOR...approx 800 horse.............ERA with 482 FE..All Aluminum Engine
Send a message via Yahoo to Hotfingrs
Sounds like you might a a couple of problems.....fuel in the oil, could be a ruptured diaphram in the fuel pump. You don't say what the plugs look like. If I'm not mistaken the 600 Holley has a metering plate on the secondaries, so you'll need the PV... use a 2.5 as suggested above...that's all I ever use. Check out the fuel pump, then start looking at plug color and play with jets.
Jack
XSSIVE .....
