Old 10-01-2003, 11:23 PM
PatBuckley's Avatar
PatBuckley PatBuckley is offline
The pushrod hole can be completely open with out any problem as the pushrod is located by the lifter and the rocker arm. It is more likely a problem if it is NOT open enough which may result in the pushrods being interfered with by the pushrod hole.
I would be more concerned with how much meat there is between the pushrod hole and the port.
As for the port - I would just smooth it out as best as I could. It doesn't look very pretty but it should work fine.
Pat
