Old 10-02-2003, 05:33 PM
PatBuckley's Avatar
PatBuckley PatBuckley is offline
What's so hard? When the tires start spinning you get out of it a bit until they stop - then you give it a little more until they start spinning again...etc.
When you are going around a turn you don't jump on the gas - even if you are running a Formula Ford you squeeze the power on...same with a Cobra.
Bad power is "light switch" power and turbo power....it comes when you don't want it and makes you look bad.
