Originally posted by PatBuckley
What's so hard? When the tires start spinning you get out of it a bit until they stop - then you give it a little more until they start spinning again...etc.
When you are going around a turn you don't jump on the gas - even if you are running a Formula Ford you squeeze the power on...same with a Cobra.
Ahhhh, like a breath of fresh air - thanks for stating the painfully obvious.
I can't use all the power I have all the time, but every time I attempt to use full throttle I have a mile wide grin and the troubles of the world are temporarily replaced by an intense high that only my shifter kart goes close to matching. Yeah - it's nice to have a little too much rather than not quite enough
