Old 10-04-2003, 10:22 PM
decooney's Avatar
decooney decooney is offline
Mike,
possibly a few other thing to check:
- a failing u-joint in R/L 1/2 shafts?
- stub axle going out (the part the 1/2 shaft bolts, goes to diff)?
- loose bolt in forward arms/rods on either end?
move fore/aft a few times from 1st to reverse to see if you can recreate it and have someone stand to the side of the car to see if you can locate which side it might be on. Good Luck.
Duane
