Old 10-05-2003, 09:44 AM
Cobra75's Avatar
Cobra75 Cobra75 is offline
Cobra Make, Engine: CSX 4100-Shelby 75th Anniversary Edition
Send a message via AIM to Cobra75
Originally posted by David Kee
Any early passeneger car bellhousing that is a 6 bolt will work. There are 157 and 164 tooth flywheels so be sure and get the correct bellhousing for you flywheel. The T-5 bellhousings will not work because they are deeper. The pilot bearings are the same size.
Thanks David. Since we are converting from an auto trans, we will be replacing the flexplate with a flywheel. If we get the bellhousing first, we'll order the correct size flywheel...now the question is how to tell which tooth flywheel the bellhousing is made for?
For example is this bellhousing made for the 157 or 164 tooth flywheel?
Scott Harrison
CSX4100
Growing old is mandatory...growing up is optional.
