Old 10-05-2003, 03:45 PM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Ditto. Griffin rad swap involves specially made rad, different rad to frame mount, and the correct way of mounting the fan (and fan selection and wiring). A little on the pricey side unfortunately, but it works. I installed the CR Griffin rad conversion kit, and it works great.
If using March pulleys, get the "Street Rod" ratio, not the "Performance" ratio. And use somebodys' (Edelbrock, Stewart, Wyand, etc.) high flow water pump.
I've read on this forum of aluminum and brass radiator options that will save a few bucks, but don't include the radiator and hood bracket you need to make everything work, and fit.
Don Scott is a straight shooter. If he suggests a solution, go for it. It will work, and will be the most cost effective.
A Cobra builder needs to prioritize his build budget to cooling system, electrical system, suspension, steering, and brakes. Then build a moderately warm street motor to go in it. The Cobras that guys won't part with follow these build guidelines. The Cobras that wind up on e-Bay with 600HP motors for seemingly low prices didn't.
