10-06-2003, 10:56 PM
CA
Cobra Make, Engine: Lone Star Classics, LS 427, 302 cid @ 370 HP, T5 and 8.8" rear end, 99.99% complete
Originally posted by FUNFER2
Mine is the 2000 year model before they re- tooled the body. I'm now rebuilding the motor. (long story) The engine builder screwed me on the internal parts when built. I paid for all the good parts, forged pistons, (got cast), rods, bearings, windage tray, ect....The builder used cheap..thin walled valve guides, these expanded & contracted finally seizing #1 valves, bent the push rod & breaking rocker shaft. (it did not have end stands). When I pulled the head I found CAST, pistons so, I tore down the entire engine & I'M...building the correct way. I'm trying to get him to pay me for the parts & labor that I paid him for...we'll see what happens ! Anyway, the Lonestar is a great car & have talked to the shop guys many times & have been very helpful. I recomend them to everyone.
Question guys, are any of you using 15" wheels ? I hear that we can't use 10" wide rims, they will hit the frame, in front, of the rear tires. I really don't want to buy new 17" wheels so that I can have fatter tires.
kev
I am using the 15" Team III wheels and at 9.5" they just barely fit. The tires are close to the top of the fender well. I probably could have moved the offset in an inch but things are pretty tight everywhere. I had to do a little grinding on the rear disc caliper castings to stop a slight rub on the inside of the wheels. I do love the look of the Team III wheels.
Chuck
