  #23 (permalink)
Old 10-07-2003, 08:03 AM
Bart Carter Bart Carter is offline
Cobra Make, Engine: Levy Racing built FFR w/351W
Default Re: Re: Re: I Want It, But How Much Will It Cost?
Originally posted by Sizzler
Are you sure that isn't for the iron block 5.4l available in Ford Trucks now?
Weight given is 315 kg, which is 694 lbs. Includes:
AL block - all-new aluminum block cast from 356-T6. The improved alloy is said to be 20-30 percent stronger than the alloy used for the DOHC 4.6L. Billet-steel 4-bolt mains. Bearing-cap brace/windage tray that mounts to the main cap bolts.
AL heads - 8.3:1 compression
Supercharger
Dry sump
Weight includes clutch and oil reservoir
Goals were to beat a Viper in a straight line and a 360 Ferrari around the track.
Engine may see duty in the new F150 Lightning and the '05 Mustang Cobra
