Old 10-08-2003, 02:31 PM
ENTDOC's Avatar
ENTDOC ENTDOC is offline
Default radiator problem with 351c
I have a 351c in my Hunter and now that I can run it I have noticed that the overflow port on the Moroso T filler starts leaking at about 170 degrees.I changed caps(16 lbs) but still leaks. thought this should not happen untill greater than 200 degrees or so.I do not have a thermostat in place but that should make no difference, should it? chuck
