Old 10-08-2003, 03:23 PM
cobrajeff's Avatar
cobrajeff cobrajeff is offline
Default Water Restrictor Plug
If you do not have a thermostat, you MUST have the "water restrictor" plug in the block of a 351C - it is located beneath the thermostat, and looks basically like a gutted thermostat. If you do not have the restrictor, your Cleveland will pump water through the radiator so fast that it does not have time to dissipate the heat.
regards,
Jeff
CobraJeff
ERA P 202
