Old 10-09-2003, 01:31 PM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
Roscoe,
You may wish you had bought a Mighty Vac if "Barbara" reads this.
REDC'
I have the Mighty Vac and I have used it for my clutch and brakes as well as siphoning gas from my barrel to my fuel cell (I change hoses of course).
I haven't had an occassion to add or subtract fluid from my trans or diff but I wouldn't hesitate to use the Mighty Vac. If you do use your Might Vac to bleed your Hyd clutch get back on line I found an easier and quicker way using the Mighty Vac.
Good Luck,
Clois
"Let's roll"
"Be part of Something Good
