Don't know a lot about SCDA, but they were more expensive than several other clubs at the same venues. Maybe they run less cars and give you more on-track time. As far as NHIS (or Lime Rock as well), you will need to address the sound regulations. Small blocks get by with a lot less fuss than FE's. My FE passes both tracks with the same mufflers, although NHIS says 99db and LRP says 89 (or 87). Just where and how they measure. You should also look into COM. COMSCC.ORG I think. They have a VERY comprehensive training program, and run timetrials on the second day.
As far as the single hoop bar...most groups frown on instructional student cars without equal safety equipment for the instructor. Some will do lead/follow, some not. Experienced, signed-off drivers generally have no problem, as long as the bar is "real". Your SPF should be fine if your head doesn't stick up above it. Olthoff makes/installs a fullwidth setup.
You'll need a 5 or 6 point harness, current helmet, and arm restraints too. E- mail me your evening phone and we can talk more. Been doing this for 13 years.
Don
