Old 10-12-2003, 04:56 PM
Eljaro's Avatar
Eljaro Eljaro is offline
Cobra Make, Engine: Contemporary with 482 KC/SO, TKO600,IRS Jag/AMP, 3.54 Salisbury PL,
Default Larger disks for jag susp.
Check out AMP at http://www.cobracountry.com/amp/home.html
they make good front suspension replacements for Jags. My front brakes have Disk diameter 310mm,
Disk bolt circle diameter 175mm,
Disk inner diameter 162mm,
Disk thickness 21,08mm(13/16") and use Willwood Superlite calipers with an adapter plate to fit to the original upright.
Check these pictures
