Old 10-12-2003, 05:48 PM
vettestr's Avatar
vettestr vettestr is offline
Cobra Make, Engine: Cobray-C3, The 60's body lines on todays chassis technology
Ernie,
I asked for your reponse and thanks but a 90's 5.0 Mustang transplant is just as boring but I do offer Ford motor plates and mounts so you can install the big or little Ford motor. Vette frame is 98 inch wheelbase plus 5 inches wider than most and with IRS rear and 4 wheel disc brakes and every performance suspension part made is available as a bolt in replacement. Stock handling is pretty impressive with bigger footprint and some 30 years of technology updates. I went full track ready route on suspension. Front coils replaced with mono fiberglass spring ,tube upper and lower control arms with modified geometry and 14 inch rotors. Hand built adjustable shocks and 4 corner weight jacks. The motor selection in mine is an aluminum Dart 542 inch stroker, injected on gas now, alky for the street was just too much hassle. So did not go the cookie cutter approach by any means. My question or point was more from trying to understand the nose in the air ( if it is not 100% copy of Shelby why bother). I am not now nor have ever tried to build a COPY/CLONE or tried to fool anyone. I build a toy inspired by the awsome looks and lines of Cobra and thats it. I do not think that makes this any less an expression of me or my toy. You do not have to love it but would like it if after looking it over said it was clean and a quality build with some good ideas even if you do not know what to call it.
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
