Old 10-12-2003, 07:08 PM
ccomt ccomt is offline
Cobra Make, Engine: EM Replica, 427 s/o, Vette suspension
"I can ground the sending unit itself to the battery, and the gauge will sweep all the way up....but when I put a jumper from the stud part of the sending unit to the block...nothing happens. "
This sounds like it could be a grounding issue. Since the gauge will read at max when you ground the sending unit to the battery, the gauge should read at max when you run the jumper to the sending unit stud if you had a proper ground. Are you using a lof of teflon tape on the sending unit?
Just my $.02
*** OF GREAT WORTH *** And JESUS asked again, “The Kingdom of GOD, how shall we think about it, and to what can it be compared? Is it not like a Dark blue 427 Cobra, which a man found parked on his street one day? He hurried off and sold all that he had; the ’57 Thunderbird, the ’63 Stingray, the XKE, and bought the dark blue 427 Cobra.” The disciples frowned and scraped their feet; JESUS grinned and popped the clutch. --- Harris Wolfe
