Old 10-12-2003, 11:06 PM
Keithc8 Keithc8 is offline
Default Club Cobra CNC 427 Head Special
We are making a special deal on our cnc ported Edelbrock 427 heads to Club Cobra members. These heads are second to none as far as a bolt on head that will work with stock type intake and exhaust. These are the same heads we have used to make 850HP with our race FE's. The flow numbers are as follows. Intakes lifts .300-215CFM, .400-275CFM, .500-318CFM, .600-350CFM, .700-372CFM, .800-384CFM. Exhaust lifts .300-160CFM, .400-200CFM, .500-230CFM, .600-250CFM, .700-260CFM, .800-270CFM. These heads will have one piece stainless valves, 10 degree titanium retainers and locks, inner spring cups, teflon seal, Comp Cams springs, with the valve job done for either street or strip use. They will be assembled and milled to your desired chamber cc's. The cnc chambers are about 80cc which works good for street applications and can be milled to 68cc with no problem. These heads are being offered for 3395.00 complete for flat-tappet or hydraulic roller applications and 3595.00 for solid roller applications. No one can offer these kinds of flow numbers for this kind of money. I said I would have some good deals for you guys and this is just the start. Thanks Keith Craft
Keith C
