Old 10-14-2003, 07:59 AM
nikbj68's Avatar
nikbj68 nikbj68 is offline
Cobra Make, Engine: Hawk 289FiA with Le Mans hardtop. AC CS(X)2131,289 (my father owned it from `67-`73)
Originally posted by HIQ
It is appropriate to put AC badges on the car IF it is an AC. It is appropriate to put Shelby Cobra badges on a car IF it is a Shelby Cobra.
Why mark the car as something it is not?
It would be appropriate to badge an AC as an AC. Even a Shelby....as they had the AC badges taken off on delivery from England.
OK,the legalities of mis-badging a replica are an area we all know about, copyrights & TM`s. But if you want the look, it`s up to you.
Originally posted by CRZN427
galaxy,
My early research on the subject led me to believe the the original Cobras, the 289 cars, were made in England by AC and shipped to Shelby in California for installatin of the power train.
Those cars had the AC badge and were known as "AC-Cobras".
When Shelby wanted to upgrade the car to to use the 427, and there were several reasons to do that, the Brits balked at putting that much power in the car, they said it is too much for the chassis. That is where the Shelby quote "Too Much Is Just Right" is said to have originated.
Shelby brought the majority of the manufacturing to California and modified the chassis to accept the big block with such upgrades as stronger material for the chassis, A-Frame coil spring front suspension, in lieu of the AC's transverse leaf spring, wider body to accept the bigger tires and a stronger transmission and rear end for the added power.
These cars had the Snake/Shelby badge and were known as "Shelby Cobras".
There are probably 289 Cobras out there with the Snake/Shelby badges but I believe that they were changed out after the development of the other badge that depicted the Shelby name.
Correction comments are welcomed.
Correction comments! ALL original Cobra Chassis were made at AC`s factory in Thames Ditton. All the bodies were made for or by AC in England. ALL Shelby`s Cobras arrived as a "turnkey minus" via air or seafreight.
Certainly Shelby made improvements & modifications that may have made their way into production, but that was all done at AC`s factory.
"If I plagiarize, it's only because I like someone else's idea better than mine and I want credit for it."- Anna Sato-Williams.
"If I plagiarize, it's only because I like someone else's idea better than mine and I want credit for it."- nikbj68
