Thread
Brake & turn signals
permalink
10-15-2003, 12:51 PM
Rick Parker
This is for you ERA guys. Have any of you had problems with the trailer wiring convertor used for the Brake & Rear signal lights. This is no reflection on ERA at all. Just a general wiring question They use the part and I have too. I am currently chasing turn signal and brake light issues and think it may be this problem, I seem to have good grounds as the running lights are fine as are the headlights both high & low beam. While operating RR signal, with key on, LR running light dims a little each time the RH flasher cycles. I cannot get any LH turn signal, I have LH stop light but not RH. Bulbs are good. There is also an unusual vibrating noise coming from the trailer adapter under the dash when the signal is operating. Again this has nothing to do with ERA. Others may use the adapter but I'm not sure.
Almost done.....
Rick:
12:54 PM
Rick Parker
View Public Profile
Find all posts by Rick Parker
