Old 10-15-2003, 09:46 PM
Keithc8 Keithc8 is offline
Default BlueThunder FE heads
Chas, the 380 flow number is at .800 lift, the Edelbrocks we do will flow about 355-360 @ .600 lift. The 2x4 set up you have is plenty of carburation for your application. The 2x4 carburator set up are always harder to tune and it depends on how the carburators were prepped. We like to use a single four for best performance and drivability. we will normaly use a 850-950 with these heads and make from 600HP to 800HP depending on the size and options.
RDorman, we are a blue thunder dealer and would be happy to check on a intake for you. give us a call at the shop and we will check it out for you
Thanks, Keith Craft
Keith C
