Old 10-17-2003, 08:44 AM
CobraVMC CobraVMC is offline
Default Clutch Slave ??
Ok, I'm confused. I have 351w with a lakewood bellhousing, 11" Ram clutch. The pivot ball is upper passenger side in the bellhousing. If I have it set up correctly, which I'm questioning after reading these post. The fork needs to go to the front of the car, towards the bellhousing as you say. I would think this would work fine ??? And I could use a push or pull slave for it depending on where I want to mount it. Is there a perfered way to mount the slave ??
