Old 10-17-2003, 10:18 AM
Jamo's Avatar
Jamo Jamo is offline
Super Moderator
Ed
CobraRestorers sent me one when I asked for a replacement for a single carb...but it's shorter than what I wanted. It's a tiny bit shorter than the original S&H foam element. The only number on it is 0828A. Should work fine for two carbs. I believe the number Steve gave up above is close to the original specs as well...2570. But please call K&N and double check the specs on those two numbers. Remember that the diameter of the S&H is about 8 1/2 inches.
blykins
I don't accept apologies. I do accept new found friendship.
Jamo
