Old 10-17-2003, 10:53 AM
dalola's Avatar
dalola dalola is offline
Cobra Make, Engine: Project "X" underway....twin turbo V6, AWD...
Cool
If you have power steering, you may want to investigate one of the hydro-boost systems. Similar to the GN set up, but works through the P/S system.
A friend of mine just installed this system on his car. He did the big Baer brake swap, and just couldn't generate enough line pressure to work them effectively. Big cam, and low vacuum, so that was ineffective. The hydro-boost system is a very clean installation, and it flat out works!
If you don't already have P/S, you could add it just for the brakes, without actually plumbing in a rack.
I'm trying to think of the company that sells this system. They are in Michigan. I'll think of it eventually!
Anyway, something to think about.
~Dave
