Old 10-18-2003, 10:00 AM
FFR428's Avatar
FFR428 FFR428 is offline
Cobra Make, Engine: HM-2027 / 427 SO
Yes those pesky service blocks with no #'s. I had a 28 block the same way. Wasn't sure if the 27's were the same. The heads are indeed the marine type and are similar to the low riser type. If the crank is a revese rotation ot should carrie the C5JE-B or C6JE-D casting numbers. These are the 2 i've got listed for the RR marine cranks. Rods are the STD 27 bolt and nut type. Block has the crossbolts yes? Sounds like a good find if the $$$ is not too steep. Hope this helps, G.
