Old 10-18-2003, 10:00 AM
Rick Parker's Avatar
Default Thank you ERA
The brand I have found and the part number being used is #18158 made or marketed by Draw-Tite??? Is this the correct item? If not may I purchase one from you? I am somewhat confused over the labeling "Input/Output".
The label on the convertor clearly indicates the side with two wires labeled as "Input" and the side with 3 wires is labeled "Output". Yet when applied to the wiring diagram (FIA) the 3 wire side is directed to "The car" (input??) and the 2 wire side to the tail lights "Input??".
I reordered before removing the original, and find myself questioning whether I actually have the correct item. To my interpretation, the side with 3 wires should be "Input", and the one with 2 wires since it goes to the rear light should be "Output". What am I overlooking? (interpretation)???
Rick
