Old 10-20-2003, 01:19 AM
cobrashoch cobrashoch is offline
Cobra Make, Engine: Home built, supercharged 544cu/in automatic
Easy there Ernie. It's o.k. to do this to the front hubs if done by pro's. Though up front wise, new hubs will cost you about the same as getting the work done. So I wouldn't recomend it as a practical cost saver towards new front hubs in most cases. Costs are also determined by the type of front brakes you are using of course.
I had this done when I narrowed the rear for my car too. I had them cut the lip off the face of the axle to set it up for a Wilwood hub, and had them put in screw in lugs.(recomended) I went from a 5in. bolt pattern to a standard Ford pattern and had the old holes welded up and turned down. The standard Ford 31 spline axles are MUCH stronger than most aftermarket performance axles of the other camps. Greg Moser was the folks that did this for me here in Indy (Muncie) and this is a common thing and standard fair that is done in hot rodding and drag racing. It's o.k., but I would still have Moser or who ever pro you are using look the axles over before cutting on them. They could be bent, cracked, or whatever. It's also cheap to put new wheel bearings on at this time.
Shipping is only a few bucks and they can be overnighted if in a rush, and Moser gets this type of stuff done in one day normally. That is, if you can't find someone local. Greg Moser advertises everywhere in hot rod books and is on the net.
cobrashock
Ron Shockley
