Old 10-21-2003, 05:20 PM
RedCSX RedCSX is offline
Default I am off on my math! Well the 427 is almost done.........
Keith,
You right I am off, forgot about that very expensive Aviaid oil pan $550 dollars and that Mighty Demon will blow my budget 500.00. and the rocker assembly help put me over 7K. Total will be closer to 9K actually $8949.00.
Here is what I have:
1963 427 Center Oiler.
Short block, machined with 427 crank turned .010, Lemans rods wirh Chevy pistion pins/ Ross Forged Pistons/ True roller billet gear/duble roller timing chain, ARP bolts throughout, polished timing cover. All the oil work done, Blue Printed oil pump and large shaft. $4,200
Custom ground cam and solid lifters from Cam Research $300.00
New Cobra 427 valve covers $150.00
Blue Thunder single four barrel intake $400.00
Edlebrock heads (bare) $950.00
Porting and flowing of heads and five angle vavle job by Trans Am Racing $800
MSD billet distributor/ignition/coil/ wires $300.00 (such a deal)
Mighty Demon Carb $499.00
Billet Shafts/stainless rockers/springs/valves/ and nascar push rods $800.00 (good to have friends)
Morgan
RedCSX
