Thread: 428 Carb Set up
Old 10-22-2003, 07:08 AM
CJ428CJ's Avatar
CJ428CJ CJ428CJ is offline
Cobra Make, Engine: ERA #629, BBM Side Oiler Block, 482ci, Richmond 5 speed
Chaplin,
If you're happy with the cam other than the stumble you refer to, I'd buy and install a new carb before I replaced the cam. I run a fairly lopey cam (Isky .565 lift, 280 adv duration, 232@.050, 108 LC). I pull only about 4 inches of vacuum at idle. I had a Holley 750 DP on it that I never could get to run really well. I pulled it and replaced it with a Demon 750 DP. I had to change the power valve to a 3 inch valve and I reduced the jets by one size. It runs great now with no hesitation.
Bottom line is, your problem seems to be a carb problem and not a cam problem. Lots of other people run cams with the same or less vacuum than you have. And installing a new carb is sooooo much easier than replacing the cam and it's not much more money.
Chris
