Old 10-24-2003, 09:47 AM
Tony Radford's Avatar
Tony Radford Tony Radford is offline
Cobra Make, Engine: Unique 427 SC, Southern Automotive 427W Stroker
Default Demon carb tuning question
I've called Barry Grant techs twice on this issue and got two different answers. Here's the deal. I'm running a Mighty Demon, dual squirt, mechanical secondaries carb on my Windsor stroker. It idles great, throttle response is superb, runs great throughout the RPM range. My only issue is that when I come to a stop, the RPMs drop almost to a stall until the car comes to a stop where the idle jumps to normal. Doesn't this sound like a float issue? BG recommends that the fuel level in the bowls should be in the center of the windows. Mine is set at the bottom edge of the window. One tech said the butterflies needed adjusting. The other said to raise the fuel level in the bowls. I don't want to screw with this thing in the wrong way. Any advise?
After a good hard ride.....oil pressure is over 50, temp is below 190, she idles and no new dents. LIFE IS GOOD!
