Old 10-25-2003, 07:02 AM
simonjrwinter simonjrwinter is offline
Default oil pressure problem
My rebuilt 331 stroker engine (with 100 miles on it) runs really sweetly. However I'm a bit concerned with the oil pressure.
On start up it goes up to 40lbs (ish) per sq in and pretty much stays there. As I'm running it in I haven't revved it too much, but anywhere between 1,000 and 2,500 revs and the gague stays put. It doesn't seem to get significantly lower when it's hot either.
I fitted it with a secondhand (but brand new and unused) TRW oil pump that I was told was high volume, also fitted the SVO hardened oil pump shaft as was recommended. I stripped the pump down to check it all out, and thoroghly clean and lubricate it before putting it back together. I can accept that I was screwed up and sold a standard pump but surely it shouldn't act like that.
I think my next step is to get a capilliary oil gauge and test the pressure "manually" without relying on the sender and gague (both working fine with last engine) does anyone have any advice?
What if the pump really is only pumping out 40psi? is there a valve that might stop it producing more that could be faulty?
Thanks guys, and help appreciated, I don't seem to have much luck with engines.
At over $6 per gallon, we must REALLY love our cars in the UK !
